Bad jamming / skipping with E3Dv6 and Taulman 645
Posted: Sun Aug 23, 2015 10:03 pm
halp.
I've changed the gearbox pinon (was slightly worn), greased the gearbox, set the motor current to "200" in Marlin (1.2A?), tried all tensions on the idler, brand new E3D nozzle (0.4mm), heatbreak fan running at 50C and hotter, and a filament oiler (tried dry and oiled), with well-dried Taulman 645 Nylon.
I'm running 0.2mm layer height, 260C, 30mm/sec print speeds.
Anywhere from 2-60 minutes into the print, the filament will strip out. If I retract, cut off the stripped part, and feed it back in, I get immediate and severe skipping (very ratatat instead of click, click, click). If I swear at it and leave it alone for awhile, it works fine. The nylon is making it down to the nozzle and not catching on something on the inside (it might be dragging, but its at least not fully hung-up). Other than ordering more nylon, I'm running out of ideas
