Where is two piece Zstop adjustment
naturalstate720
Post by naturalstate720 » Mon Nov 09, 2015 9:55 pm
Was I hallucinating or was there a two piece plastic adjustment for the Zstop bolt? I'm having a heck of a time adjusting the screw and I thought I saw one that was two pieces to tighten by hand.
I see this one that attaches to the bottom. http://www.thingiverse.com/thing:105616
Is it worth adding both of these or one of these?
Also can someone explain why I need the z axis stay? http://www.thingiverse.com/thing:53886
It says that it holds the platform up while the steppers are off? When I press the 'disable motors" the bed doesn't fall, it just allows me to manually move it. Can someone explain please.
Thanks
3dPrintingMD
Re: Where is two piece Zstop adjustment
Post by 3dPrintingMD » Mon Nov 09, 2015 10:05 pm
The newer machines don't need the Z Axis stay. The bed stays up no matter what.
wmgeorge
Post by wmgeorge » Tue Nov 10, 2015 1:48 am
naturalstate720 wrote:Was I hallucinating or was there a two piece plastic adjustment for the Zstop bolt? I'm having a heck of a time adjusting the screw and I thought I saw one that was two pieces to tighten by hand.
Thanks
I posted my method here > viewtopic.php?f=10&t=1998&start=30
Post by jsc » Tue Nov 10, 2015 5:16 am
3dPrintingMD wrote:The newer machines don't need the Z Axis stay. The bed stays up no matter what.
Really? Wonder what changed? Are you sure it's not just lack of lubrication?
3dPrintingMD
Post by 3dPrintingMD » Tue Nov 10, 2015 6:09 am
Yeah very sure, this puppy is well lubed. It never stayed up, I've been wondering that since day 1. I've seen so many Z stay things, and I'm like, I just dont get it.
Post by sthone » Tue Nov 10, 2015 4:21 pm
3dPrintingMD wrote:Yeah very sure, this puppy is well lubed. It never stayed up, I've been wondering that since day 1. I've seen so many Z stay things, and I'm like, I just dont get it.
I'm confused by your contradicting posts :lol:
Post by ednisley » Tue Nov 10, 2015 4:26 pm
jsc wrote:Wonder what changed?
That "free fall" depends so critically on having those guide rods be exactly parallel that it's a wonder any Z platforms fall freely. The Z platform support is overconstrained: one of the linear bearings should be a pair of pinch rollers clamping its rod to prevent rotation around the other rod.
The Z-axis leadscrew adds yet another constraint, which is why it needs a little bit of slop around the top bearing. After I replaced the Z motor, the platform no longer fell freely; it moved smoothly with the motor unplugged, but had enough restraining force to hold it in place.
As long as it's not binding, life will remain good...
3dPrintingMD
Post by 3dPrintingMD » Tue Nov 10, 2015 6:24 pm
My bad, the bed stays up. It never falls down.
Post by sthone » Tue Nov 10, 2015 6:59 pm
So it just stays up after a print is done too?
Both mine drop like rocks so I use Jule's end script to bring them down slowly after a print... if yours does stay up after the print you could probably use a modified version of that script too if you don't all ready. (see #10 under "The Settings:" HERE)
3dPrintingMD
Post by 3dPrintingMD » Tue Nov 10, 2015 7:47 pm
Yes, after the print is over, the head just moves to the side, and the bed stays right where it ended.
I'll look now.
