First time posting here. Just wanted to share the enclosure I built for my printer. After moving into a new house with less ventilation for 3d printing, I wanted to build an enclosure system that focused on reducing fumes/odors/microparticles in my living quarters. First, I needed to ensure the enclosure was as well-sealed as possible. Secondly, I wanted to build in an active filtration system to reduce the amount of noticeable fume buildup within the enclosure.
My enclosure is pretty basic. It's a box made of 1/2" birch plywood, primed with Kilz odor-blocking primer and spray-painted white on the interior. An inner frame along the opening provides contact area for the rubber seal strips (functioning as a gasket of sorts) that come into contact with the inner frame of the door. The door is detachable and is held tight against the inner seal via toolbox-style spring-tensioned latches to ensure a decent seal. I'm not sure if I'm crazy about the detachable door design, but it's also a large door to have swinging around in a smaller space like my office.
Next was the filter. After doing a little research, I learned that I needed to combine carbon filtration with HEPA to tackle both odors and microparticles. I found a design I liked a lot here, and I adapted it into a basic design I could include in modular form inside the enclosure. The end product was maybe one of the uglier things I've built, but it seems to function so far.
Full Imgur album here with some build progress shots and other notes
I've yet to test all this together, but I'm hoping tonight will be my first successful test run. This is one of my first woodworking projects, and I think it turned out pretty well.
