Jim, you need to make the disclaimer that you're building on a metal plate when you say things like that. I've found the PETg filaments to have very well-defined cut-off points between sticking well and not sticking at all, both for the extruder temperature and for the bed temperature. On the glass bed, that temperature sits right below 90C for all of the filaments. I print at 90, and when it's holding that temperature, the part is stuck firmly and can be very hard to get off even with a razor blade. As it cools down, somewhere around 80 it loses adhesion completely, and often I can just pick the part right off the glass. The difference between your experience and mine may be due to the temperature that the bed can keep on the surface when the fan is blowing on it. That must be different for a metal bed vs. a glass one.jimc wrote:I actually run the bed 70-80. Never hotter than that. Its just not necessary.
For extrusion temperatures, I've found small but significant differences between the colors. Blue prints well at 245 for me. Yellow won't stick to the glass at 245, and I have ended up cranking it to 255 to get it to put down the first layer reliably. The ruby red, I have been printing at 255 just because I haven't changed the settings since I was printing with the yellow, and I haven't experimented with how much lower I can take that without losing adhesion to the bed on the first layer.
The color of the translucent PETg filaments is just phenomenal when the printing speed is slow, but it gets dull at normal printing speeds. Infill dulls it a lot, but by giving it a high perimeter count, you can print lots of concentric perimeter rings and get the same fantastic color as you get with single-layer-thickness prints.
