fixing self inflicted problems that raise hell with the V3B hot end from junk filament
purchased for Amazon and Makergeek. Amazon? ...never buy a unrated filament, then
do so at your own risk. Makergeek's extra glow ABS caused me 2-3 days of grief,
that had to be mis-labled PLA.
Next issue and it's a big one is keeping the filament dry. Moisture content and how to remove
it and keep my used filament dry is the next thing on my list. Figured out excessive droll was
from moisture expanding inside the hot end.
I use a lot of PET+ because it's stronger than ABS. Recently, purchased a spool of clear from Amazon.
Thought no biggie, when the spool arrived with torn, broken vacuum seal and missing the dry stuff packet.
OK, more problems, this PET+ was more grief with droll that seemed to go on forever, leaving zits
on my models every retraction cycle. Good thing about Amazon is their return policy and getting
your money back asap.
Another bad idea that I had was purchasing the tiny clog clearing drill off Makergeek.
This crap tool broke off inside one of my hot ends, after it made the opening in another
way too large.
I'm done trying to clean hot ends, for 10 bucks new from Makergear will save me one helluva of time.
Sure it's 10 bucks out the window, but what's your time worth? ...not to mention the frustration meter?
Something worth sharing is keep hot ends and drives dedicated to either PLA, ABS, or PET+.
Changing different kinds of filament back and forth in the same hot end is where I've had too many issues
to continue this practice.
If you have a good way to store filaments, or a small affordable dehumidifier system
please share it.
