Simplify3D 2.1.2 is out
sprior
Post by sprior » Sat Sep 27, 2014 1:58 am
Just fired up Simplify3D 2.1.1 and got the upgrade notice for 2.1.2.
Here's the changelog:
Added support for OS X 10.10 Yosemite
Improved Mac and Linux 250000 bps baud rate support
When using the Import button, the user can now select multiple files to load at once
Brim has been improved so that it remains attached to the part, even with support material enabled
Added support for up to 6 different extruders
Bed Leveling Wizard now supports a wider range of custom XY coordinates
Added pre-configured profiles for the Leapfrog Creatr XL, ZYYX 3D Printer, Multec Multirap M200, and German RepRap NEO/PRotos/X400
Added the ability to remove multiple profiles at once
Filament cost calculations are now compatible with a wider range of currencies
Quality auto-configure XML tags can now be nested inside of material auto-configure tags to allow more detailed settings combinations
I'm curious what they actually improved on the multiple extruder front - anyone know?
Re: Simplify3D 2.1.2 is out
Post by jimc » Sat Sep 27, 2014 4:58 am
Not much on this update. The next update is supposed to be a bunch of dual ext upgrades.
