First experiment ABS/Ninjaflex dual print
Re: First experiment ABS/Ninjaflex dual print
Post by insta » Mon Feb 09, 2015 3:42 am
sprior wrote:I've now got small pieces of NinjaFlex in a jar with acetone and another with alcohol. Will see what happens by tomorrow.
Try a 3rd one with some kind of acid. Muratic acid is cheap and may attack it. I know it's one of the few things that shows Nylon its pimphand.
sprior
Post by sprior » Wed Feb 11, 2015 5:18 am
Well that was interesting. I forgot about my little experiment last night, but just remembered so both samples got a 2 day soak instead of 1.
The NinjaFlex in denatured alcohol sample showed no noticeable difference, I'm not surprised.
The NinjaFlex in acetone sample didn't dissolve, it actually swelled from 1.75mm to 2.2mm, but otherwise seems quite intact. It'll be interesting to see whether it shrinks back down when left to dry.
Post by jimc » Wed Feb 11, 2015 5:21 am
thats pretty much what i figured on the acetone. if you let it set out for a day it will go back.
