Burned out board
Re: Burned out board
Post by ednisley » Thu Jan 22, 2015 5:32 pm
M. Beneteau wrote:Do you have any suggestions?
No matter what you do, those connectors simply won't withstand the high current required for a 12 V platform heater.
You can remove the charred connectors, solder husky wires directly into the PCB holes, and then put Anderson Powerpole connectors on the wires:
viewtopic.php?f=7&t=169&p=1616&#p1586
Or you can replace the connectors, but use them to drive an external DC-DC solid state relay that can handle the current:
http://softsolder.com/2013/10/11/makerg ... hermistor/
Obviously, I like the SSR, but you should definitely use Powerpoles for high-current connections.
M. Beneteau
Post by M. Beneteau » Sat Jan 24, 2015 10:28 pm
Thanks, Ed :) Just squared away with the block connector that can handle 18A... hopefully it holds up :o
My power supply is the 12v 19v split from 2 years ago. It works fine when the contacts are on. Maybe i just need to reduce vibration while printing and connections will hold better...
Are you using the new E3D extruder? I would like to know if it really is as good as they say.
Thanks,
Mike
Post by ednisley » Sat Jan 24, 2015 10:52 pm
M. Beneteau wrote:reduce vibration while printing
Also, anchor the power supply cables so that they cannot pull on the connectors: those poor things run on the ragged edge of their rating and need all the help they can get.
I'm still using the original hot end, but expect a long-awaited MG V4 in a week, assuming the January ship date remains valid.
Post by insta » Sun Jan 25, 2015 9:45 pm
M. Beneteau wrote:Thanks, Ed :) Just squared away with the block connector that can handle 18A... hopefully it holds up :o
Thanks,
Mike
You *really* need to not be using the 12v setup anymore. There is zero margin for error with it. It'll generally survive PLA temps, but I repeatedly ran into issues trying to reach ABS temperatures, and suffice to say I'm on 24v now.
M. Beneteau
Post by M. Beneteau » Wed Jan 28, 2015 8:21 pm
Thanks for the input all. I guess will save up some coin for the 24v upgrade to further the ABS format :)
TTYL,
Mike
