Movement
Posted: Mon Aug 25, 2014 2:48 pm
by printboss
The groove mount is moving inside the filament drive housing. Has anyone had this problem?
Re: Movement
Posted: Mon Aug 25, 2014 3:33 pm
Your mount may have a crack. See if you can find the crack, repair it with epoxy temporarily, and print a new one in ABS. You may be interested in this one:
viewtopic.php?f=7&t=674&start=16
Re: Movement
Posted: Mon Aug 25, 2014 4:40 pm
by printboss
Thanks for your response, but no im not seeing any cracks. Yes I may need to print out a new filament drive as to mine is not holding the barrel tight. Can I use any epoxy?
Re: Movement
Posted: Thu Aug 28, 2014 10:21 pm
by Lateralg
I used small metric equivalent of fender washers with 3mm screws into nuts in the nut traps in the filament drive. I don't see a downside to this. Am I missing something?
