Good Evening!
I have an older M2 with the RAMBO 1.1b. Does anyone have the correct firmware for this? They have Marlin firmware, but I assume it needs to be modified to work with the M2?
Just wondering before I spend a bunch of time diving through code to get this to work.
Thanks in advance!
Need Help with Viki 2.0 and RAMBO 1.1b
Re: Need Help with Viki 2.0 and RAMBO 1.1b
Ugh, stick with the older firmware. i've had nothing but (subtle) problems with the newer Marlin builds. If you're going to modify code, use the stuff MakerGear posts on their website.
I found the code for the original Viki on the Makergear site, my plan right now is to merge the relevant code from the Viki 2.0 firmware to Makergear's firmware. Ill upload it when/if I get it running.
Besides the skipped steps, what other issues have you seen? Ed is up with the latest Marlin, from his blog, and he's not seeing any issues.
I'm holding off until they put in the JKN Advance acceleration planning.
Ed's either a lying bastard or really luckyjsc wrote:Besides the skipped steps, what other issues have you seen? Ed is up with the latest Marlin, from his blog, and he's not seeing any issues.
It was just skipped steps, but I couldn't pinpoint the reason why. It wasn't just the M2 either, I have another printer using the same size steppers for motion (an H-bot, so a totally different gantry) and both of them would skip steps in X occasionally. All 3 printers would do it reliably unreliably...
Changing to older Marlin with identical acceleration & jerk made it all go away completely overnight, no mechanical changes. Yes, the RAMBo stepper current was the same.
I`m wondering if the viki 1.0 marlin makergear fork could work for 2.0 viki ? I looked at this briefly and it looked like it was tested with rambo version 1.3....which is what i have. And confirmed to work ? I decided to go octoprint with a pi instead though !!! http://makergear.wikidot.com/m2-lcd-panel will this not work ?format13 wrote:Good Evening!
Thanks in advance!
The latter is definitely true, but you wouldn't believe anything I have to say about the former... [grin]insta wrote:Ed's either a lying bastard or really lucky ;)
If motor step timing was a general problem with the new Marlin code, we'd see a firestorm of problem reports on GitHub. Those folks run just about all the configurations you can imagine (and a few I can't), so it gets a good workout.
There's nothing quite like changing the software to bring out a latent hardware problem, though.
On my M2, (I think) changing the steppers from 19 V to 24 V induced glitches in the Y (and maybe Z) endstop cables when the steppers powered up. My (highly customized) start G-Code moves Z down, then homes Y, so enabling the steppers with M17 and waiting for half a second before the moves made that problem Go Away.
Other than that, Marlin 1.0.2 has been rock-solid.
I'm 99% sure it wont as the Viki 1.0 used I2C and the New Viki 2.0 is on SPI - two completely different protocols. Kind of frustrating it wasn't cross compatible, and now it just needs even more wires.PcS wrote: I`m wondering if the viki 1.0 marlin makergear fork could work for 2.0 viki ? I looked at this briefly and it looked like it was tested with rambo version 1.3....which is what i have. And confirmed to work ? I decided to go octoprint with a pi instead though !!! http://makergear.wikidot.com/m2-lcd-panel will this not work ?
The website info says support in marlin on rambo coming soon. Maybe drop panucatt a letter and beta test ?
