First Layer Wrinkles / Ripples
kartcrg
Post by kartcrg » Wed Dec 02, 2015 8:54 pm
Any recommendations on settings to change to get rid of them? It's usually perfectly smooth by the 3rd layer. Using PLA. Thanks!
Bratag
Re: First Layer Wrinkles / Ripples
Post by Bratag » Wed Dec 02, 2015 9:05 pm
kartcrg wrote:Any recommendations on settings to change to get rid of them? It's usually perfectly smooth by the 3rd layer. Using PLA. Thanks!
Looks like your print bed isn't level and your printhead is too close to the printbed on a couple of the squares. Relevel and reset Z height as per Jules amazing guide.
Post by Tim » Wed Dec 02, 2015 9:07 pm
First layer wrinkles like that are almost certainly due to an unlevel bed. The wrinkling occurs where the nozzle is too close to the bed. Your print covers a lot of area, which will make it challenging, but you can probably get it reasonably close to level.
Post by Jules » Wed Dec 02, 2015 9:09 pm
Check your bed level and your gap. (You see the ripples on the front ones, but not the rear prints? Indicates a bed level problem.)
Those ripples happen when the bed is too close to the nozzle for the first layer. So after you make sure it's been leveled, check the gap by re-setting the Z-stop and then doing the Z-Offset calibration. :D
viewtopic.php?f=3&t=2783 Level Bed and set Z-stop
viewtopic.php?f=3&t=3124 Calibrate the Z-Offset
Update: Awwww....you guys already had it covered. :lol: (Got to learn to type faster!) Anyway, I concur with them. :D
kartcrg
Post by kartcrg » Wed Dec 02, 2015 9:20 pm
Thank you very much guys! The bed is actually very level sans some bowing in the glass. The first layer width and calibration squares are very similar on all areas of the bed. I know my Z gap (first layer height) is too close. I have it like that so I can print directly on to bare glass with no adhesion issues, didn't even think about it causing the wrinkles. I'm sure thats it, I'll back it off a bit. Jules, your guid has been very helpful on a few occasions. Thanks again! 8-)
kartcrg
Post by kartcrg » Wed Dec 02, 2015 9:51 pm
Bumped the Z-offset and its perfect everywhere on the table now. Thanks again!!
Post by Jules » Wed Dec 02, 2015 10:01 pm
Great! (Boy you can really spot the bow in your glass, can't you?) :D
Bratag
Post by Bratag » Wed Dec 02, 2015 10:09 pm
Jules wrote:Great! (Boy you can really spot the bow in your glass, can't you?) :D
Thats part of the reason to go Aluminum build plate. No more bowing.
kartcrg
Post by kartcrg » Wed Dec 02, 2015 10:18 pm
Definitely. Meh..
Post by Jules » Wed Dec 02, 2015 10:21 pm
If mine had that much of a bow in it i'd definitely consider the aluminum. (Really do hate having to mess with the adhesive though.)
