My first test print of the sample bracelet is warped due to insufficient bed adhesion, but otherwise it turned out nicely. It appears to be a challenging thing to print due to the very small bottom surface area. I think it will be a good torture test as I learn about bed adhesion tricks. All of my limited prior experience has been with printing on masking tape or Buildtak, with lots of bottom surface area, and sometimes brims or rafts.
I ordered the Dual Extrusion Upgrade kit, too, as well as several different types of filament (from other vendors) to experiment with. But I'll stick with the factory-tested single extruder and the supplied MakerGear PLA filament for now as I learn how to drive this machine. Oh, and speaking of factory testing, I was pleased to see that my printer was factory tested by printing both the sample bracelet and my printer's own reel holder. An actual functional test print is a far cry from the QC issues I had with that Monoprice printer, which clearly showed that it wasn't thoroughly tested, and its power supply never even had power applied prior to its explosive failure the first time I plugged it in! I have to admit, when I unpacked my M2, I jokingly exclaimed "goddammit!" when I saw that its AC power cord was supplied by Monoprice!
