Can I Print Directly on the MakerGear Heated Bed Platform?
w22
Post by w22 » Sat Oct 22, 2016 4:10 pm
I've read in many third party sources that users can print on the MakerGear Heated Bed Platform directly as well as the glass plates without tape nor any other stick material, is this remotely true?
3dPrintingMD
Re: Can I Print Directly on the MakerGear Heated Bed Platfor
Post by 3dPrintingMD » Sat Oct 22, 2016 4:57 pm
Well I'm sure it could be done, but I'm not sure of the why. Also I would think that it would ruin the HBP over time.
Post by Jules » Sat Oct 22, 2016 5:23 pm
Reasons NOT to do something like that:
1. You'd have to reset your Z-Stop or Starting Height, assuming you could get it up close enough to the switch to let you print on it.
2. You could not remove the bed to cool it. (Can't pop it into the freezer to remove the print.)
3. You might damage the surface of the bed when prying off a print - then you get to disassemble the whole machine to replace it.
What third party sources are advocating printing directly on the HBP? (If you want to print on metal, get a MIC6 plate cut for it - insta does them.)
w22
Post by w22 » Sat Oct 22, 2016 6:13 pm
Thank you both for your input! I will avoid! As for the MIC6 plate cut, can prints be printed on that without tape and is the height the same height as the glass plates or do I need to alter the starting height with the leveling process again?
theboz1419
Post by theboz1419 » Sat Oct 22, 2016 8:32 pm
Any time you change the bed, you need to re-level.
SouthSideofdaSky
Post by SouthSideofdaSky » Mon Oct 24, 2016 8:55 pm
w22 wrote:users can print on the MakerGear Heated Bed Platform directly
Maybe the people saying this meant that users can print on the bare glass directly? Definitely not the bare HBP though...
