I have been using 2 different type of wood pla a copper pla a silver pla and white pla (i will add some forniture and people in red pla probably)
the building is composition of really a lot of files and i am not sure i have the energy to categorize them all and upload them on thingy-verse
some piece i actually had to print them twice with small modification of .8 or 1.2mm to make them fit perfectly
u probably can't tell from that picture but i installed LED at each floor for nights shoot i will do later on
this was difficult project as i decide to use multi material and the size is 40x40cm (scale 1:100) so i had to divide it in 4 part each floor and to make it more sturdy i never match the cut of different material they always overlap and it actually only had to glue the main exterior wall all the rest just perfectly fit (obviously it move if you bump in it)
I wont glue it as i need to reach the led switch of each led and the easiest way is to remove a piece and turn it on and place it back plus since i intend to add furniture it allow you to open up and look inside
