Streaking on the surface finish of PETG print
jfstanley
Re: Streaking on the surface finish of PETG print
Post by jfstanley » Thu Sep 27, 2018 12:01 am
The stringing is occurring between those holes your see in pic, plus you can see larger trails that are forming in between each "cup". If I could get rid of those, along with the major streaking of course, it would make a picky client very happy
jfstanley
Post by jfstanley » Tue Oct 09, 2018 8:42 pm
So, the results of re-leveling the bed, calibrating the extrusion multiplier, plus lowering the X/Y axis movement speed a bit is as follows:
This is the original Prilene filament I used in the first pic:
A small difference, but I guess the nozzle is still crashing into the built-up layer surrounding the holes..?
Here is the result using a different brand, Hatchbox:
An improvement -the streaking is still there, but less noticeable. The Hatchbox also has a deeper black and glossier finish.
I don't know what else to do, other than raising the nozzle head more when I level the bed? Dunno
Post by airscapes » Tue Oct 09, 2018 9:40 pm
I see the same results on many of my prints.. Not sure if it can be fixed.. maybe more Zlift?
