"Firmware unresponsive..."
Posted: Wed Oct 15, 2014 7:02 pm
Hey all - I'm having a problem with my M2 after a month of successful prints: During the print process, I get a message in S3D's Communication window that says "Firmware unresponsive. Attempting to force continue..." and the print head keeps going outside the perimeter of the print, I think until S3D reestablishes communication. Or the print head moves without extruding.
- It has only happened with one group if STLs I've wanted to print, some Spirograph gears.
- I made sure the STLs I downloaded were manifold by running them through a Netfabb repair, a step I had skipped the first time this happened.
- I've made the GCode with two separate recipes, one of which has been successful in the past.
- I reprinted something that had been successful in the past, and that worked just fine, then I had the same issue with the Spirograph prints again.
- The variable I haven't controlled for yet is that my successful print was from the SD card, and all the others were over USB, so I'll try that next.
- I'm running an old Mac with OS 10.7, and that's as far as that computer will ever be updated.
Any suggestions? And how do you update the firmware on the M2, and do you ever need to?
