Cold Extrusion Error Message
peterkozmd
Post by peterkozmd » Thu Nov 20, 2014 8:25 pm
New to makerbot m2 (the hardware as well as the forum). Keep getting the echo: cold extrusion error message popping up in pronterface. I was wondering if i could get some help in fixing this problem. Thanks!
Re: Cold Extrusion Error Message
Post by insta » Thu Nov 20, 2014 8:47 pm
What temp is your extrusion set at? Ceramic heater should be 180-190C, V3B 210C+.
The default firmware for the M2 cuts out at (I believe) 160C. If you're dipping down to this, we need to figure out why...
Post by jimc » Fri Nov 21, 2014 12:14 am
yes 170 is the cold extrusion limit. you will get this if you dip below......and for the love of god please watch your language around here. its MAKERGEAR!! :lol:
Post by ednisley » Fri Nov 21, 2014 3:40 pm
An intermittent thermistor connection can produce this problem: a disconnected thermocouple will look like a very cold extruder. If the hot end heats up correctly, but you get occasional "cold extrusion" warnings, that's the most likely the cause.
Heat the extruder a bit above room temperature, then watch the temperature readout while you wiggle all the connectors and cables between the hot end and the controller. I predict you'll find a loose joint or a broken wire along the way...
