Travel speed: 300mm/s. Too fast?
Posted: Sat Dec 30, 2017 3:22 am
by Swami
From Simplify3D profile provided by Makergear. Have delta printer that's set to half that speed. So, is it OK? Or what? Can too fast cause layer shift (due to missed step, perhaps)? TIA.
Re: Travel speed: 300mm/s. Too fast?
Posted: Sat Dec 30, 2017 3:57 am
by Swami
Running test at 150...
Posted: Sat Dec 30, 2017 12:32 pm
by ednisley
Swami wrote:So, is it OK? Or what?
Probably "or what", because it depends very much on your hardware configuration. Delta printers tend to be loose and floppy compared to rugged Cartesian printers, so they must run slower. You'll find exceptions on both sides of the comparison:
- Delta pick-n-place material handlers run at blazing speeds
- Allthread-based Cartesian printers shudder uncontrollably at high speeds
I've been running rapids at 450 mm/s = 27000 mm/min for the last few years, but only after painstakingly (pronounced "neurotically") verifying the firmware and hardware were capable of working reliably:
https://softsolder.com/2013/05/08/m2-vs ... culations/
In real life, travel (non-printing) speed doesn't make much difference in overall time-to-finish, because
printing speeds will be much lower.
If you're worried about reliability, slow down.
