minusbacon wrote:
Should the .15mm of retraction vertical lift and unchecking only retract when crossing open spaces be "default" settings for every print just to be safe? Or only used on prints where there are overhangs like this octopus?
You can leave it on, but it will increase print times and make your seams more visible. I generally leave it off unless I need it or think I'll need it.
Any recommendations on what I should print? I've printed a bunch of those sharks. I'm just trying to run the printer through it's paces. Mainly so I can learn and get a bunch of practice but also to make sure my M2 can do everything it should be able to do.
What did you dream of printing when you decided to get a 3D printer? Print those. For testing, I find I like both mechanical things and art models. The Stanford bunny (
http://www.thingiverse.com/thing:3731) is a classic, as is Yoda. Fun to show people, especially if you finish it with some epoxy or primer.
Do you guys keep the binder clips that clip the glass to the bed/heat plate on at all times?
I use to run without clips at all, but that depends on how well your bed fits in the spider. Now I use these:
http://www.thingiverse.com/thing:602194
With glue use, how often would you say you remove the glass and clean it? When I remove a print from the bed, obviously you can see where the part sat. When I run my fingers over it I can feel a slight indent where the part was sitting in the glue. With the z stop/offset/bed level being so picky, it just seems to me that a build up of glue stick on the glass would throw things off easily, hence why I've been cleaning it every couple prints.
You almost never have to clean it. If you want, you can clean it in place with a wet paper towel. Perhaps I let mine go for too long, but "every few prints" is way too often.
