- I really like the labels on the bags and in the pictures included in the instructions. For instance I never would have guessed that what looks like a popsicle stick to me is actually the same thing as the "applicator stick" referred to in the documentation. Is there any place online where I can see a similar diagram with different parts of the actual printer labeled? Some of the instructions on the "M2 getting started" page on the Makergear wiki were confusing for me to follow because I was not sure where to locate a specific component. For example "Once you have confirmed that all axes respond correctly, it is time to check the endstops. First activate each endstop by hand, by pressing on the silver lever until it clicks." I am not sure what "silver levers" are being referred to. So...like any good engineer I just skipped that step
- The tiny fan bracket piece on our device had snapped at one of the holes by the time I pulled the printer out of the box and set it on the work table. I am using vague language here because I am not sure if it broke during shipment or if I unknowingly broke it while unpacking the printer, etc. In any case I suppose I will be able to print a replacement once I get a little better idea of what I'm doing. In the meantime I was able to superglue it back together. I must say I am rather surprised that that particular part isn't sheet metal. I can definitely see myself accidentally snapping another one.
- General question: If the printer is not in use for a moderate period of time (e.g. overnight or over the weekend) should I remove the filament from the filament drive? What other kinds of "standard procedure" tips should I know?
I am very pleased with the printer so far other than the fan bracket piece. I spent several hours researching which 3D printer to buy and then several more specifically focusing on why we might NOT want an M2 (I was hoping to provide a "A OR B" recommendation to my manager). Needless to say I couldn't find any shortcomings on the M2 in comparison to other printers under $2000. I couldn't imagine spending almost as much money on some other printer with much smaller build volume or a wooden frame.
