Page 1 of 2
Helpful tools to print
Posted: Thu Feb 19, 2015 8:18 pm
by Vprints
Finally took the plunge into 3D printing -- have to say I'm ecstatic with my choice so far. :D
What helpful "printer add-ons" do people recommend printing? I found & printed a nice tool holder, then found it's sized for an older model -- so I've already got an awesome demo print I can show people. :lol: Anyone know of an updated/current one, or should I just design my own? I also just printed a 'reset button' as an initial test of S3D's 'high' setting, and it looks like it'll be really nice if I ever get it off the glass/glue...
Re: Helpful tools to print
Posted: Thu Feb 19, 2015 9:18 pm
by jdacal
Here are some I've printed that have worked out for me:
Tool Holder with space for the next item on the list:
http://www.thingiverse.com/make:91949
Wrenches for adjusting Z can be stored in the above tool holder:
http://www.thingiverse.com/thing:198811
This is the fan bracket I use on the MakerGear hotend made by one of our guys here (Dale Reed):
http://www.thingiverse.com/make:91947
These are my favorite filament clips so far:
http://www.thingiverse.com/make:91952
Used razor blade holder designed by jsc from this forum:
http://www.thingiverse.com/make:119153
Z Axis knob designed by jimc on this forum:
http://www.thingiverse.com/make:97679
Dust Filter:
http://www.thingiverse.com/make:91956
Fan covers designed by jimc from this forum:
http://www.thingiverse.com/thing:267921
Filament guide:
http://www.thingiverse.com/thing:154429
hotend filament guide:
I really like this one since the tube fits really nice in to it, also it replaces that little spacer between the fan and the drive:
http://www.thingiverse.com/thing:240427
And last but not least if you ever get a Viki:
http://www.thingiverse.com/make:85198
Almost forgot, I did this remix for the M2 which I'm real happy with:
http://www.thingiverse.com/thing:523415
That should keep you busy for a while... :)
Posted: Thu Feb 19, 2015 10:21 pm
by Vprints
Haha, yeah, at least a day or two. :) Thanks!
Does the bracket for the fans do much other than provide space for LEDs (which I don't anticipate adding anytime soon)? e.g. better cooling or something?
Posted: Thu Feb 19, 2015 10:22 pm
by jdacal
Vprints wrote:Haha, yeah, at least a day or two. :) Thanks!
I just liked the angle for the fan. The original was too close to the glass. I don't use the LED's on it. But there are a lot of brackets on Thingiverse you can look at.
Posted: Sun Mar 01, 2015 12:38 pm
by Vprints
Minor edit to the mutch-appreciated list of URLs above -- the tool for adjusting the Z end stop is at http://www.thingiverse.com/thing:198811
Posted: Sun Mar 01, 2015 10:36 pm
by jdacal
Thanks Vprint! I made the correction in the original.
Posted: Mon Mar 02, 2015 2:08 am
by Dale Reed
jdacal wrote: I just liked the angle for the fan. The original was too close to the glass. I don't use the LED's on it. But there are a lot of brackets on Thingiverse you can look at.
It was designed in OpenSCAD, and I think I posted the OpenSCAD source as well as the STL, so feel free to tweak. (Dead simple design -- if you want the source and it's not there, it'll easily fit in a ( code ) box here...) I set the angle for the bed fan at 40 degrees to hold the far end of the fan up a bit. With the little MG fan angle, the bottom tip of my bed fan was running into the binder clips holding the glass down (even after I removed the little handles from the clips). This holds the fan a little more flat -- NOTE that you may or may not get less cooling on the back of the part you are printing!
The space for LEDs is just a bonus! (If you have OpenSCAD, you could shrink that "cube" and adjust the offsets and make the shelf go away some.)
I'm just happy that so many people have liked that part and found it useful. Thanks, all!
Posted: Mon Mar 02, 2015 2:12 am
by Dale Reed
Oh, and I like this little holder for keeping up to 4 SD cards handy at the printer. http://www.thingiverse.com/thing:44339 It hangs over the right side of the frame, over by the electronics enclosure. Great if you're doing some big prints and want to use the PC for something else. Copy the .g file to the card and start the print from there. Unplug the USB cable and go use the PC for other stuff.
Posted: Mon Mar 02, 2015 2:25 am
by jdacal
Dale Reed wrote:Oh, and I like this little holder for keeping up to 4 SD cards handy at the printer. http://www.thingiverse.com/thing:44339 It hangs over the right side of the frame, over by the electronics enclosure. Great if you're doing some big prints and want to use the PC for something else. Copy the .g file to the card and start the print from there. Unplug the USB cable and go use the PC for other stuff.
Nice find I added that one to my collection. Thanks!
Posted: Thu Mar 05, 2015 9:42 pm
by Vprints
Finally got around to printing the snazzy Z knob. This may be a silly question, but how do you get the collar out of the stock knob? (Or does everyone just buy another collar?)
