Viki LCD Install on V4
Posted: Wed Oct 14, 2015 4:00 pm
by 3dPrintingMD
Hi All - I just wanted to ask before I get into it.
Going to add the Viki LCD to the printer. MY main concern is the firmware. I'm assuming that I should just follow the instructions on the wiki site.
Anything I need to be aware of ?
Re: Viki LCD Install on V4
Posted: Fri Oct 16, 2015 4:45 am
by 3dPrintingMD
Could use a hand here.
Did an LCD install. Everything seems fine, I have yet to do a print, but I noticed when I home my axis, the Z homes to the bottom of the machine verse the top, it seems like the Z axis is reversed.
Thoughts on this ?
Posted: Fri Oct 16, 2015 4:50 am
Flip the Z axis homing direction in the firmware -- you probably have the newest firmware (with a bottom endstop) on a machine with a top-mounted endstop.
Posted: Fri Oct 16, 2015 4:57 am
by 3dPrintingMD
Thanks for the quick reply, I need more help than that, sorry.
How is that accomplished ?
Posted: Fri Oct 16, 2015 5:04 am
by 3dPrintingMD
I should also clarify, I received a Geetech LCD from Makergear.
I'm dead in the water now, not sure how to edit firmware.
Posted: Fri Oct 16, 2015 6:12 am
Did you change the stepper wiring at all? Perhaps you have one of them put in backwards? To flip a four wire stepper, either flip the wires on one group or swap the two groups of two without changing their orientation.
Posted: Fri Oct 16, 2015 6:18 am
by 3dPrintingMD
No I literally did nothing.
Opened case, removed SD Reader, put interface card over correct headers, pushed in place, attached the 2 ribbon cables, and closed box.
Posted: Fri Oct 16, 2015 12:56 pm
by PcS
http://makergear.wikidot.com/m2-firmware
Please look at the link it should have the info you need . If you need more help after that let us know .
Posted: Fri Oct 16, 2015 1:15 pm
by 3dPrintingMD
Followed this 100%.
The firmware is bad, if you open it,you will notice settings for mendel that are not what they say it should be.
Posted: Fri Oct 16, 2015 2:42 pm
by 3dPrintingMD
Black z motor needs different firmware than what is currently on website.
This is per mg.
They will update soon.
