Hi,
I just bought a used M2 and am super excited to get started with it!!!
The M2 I bought is still set up with the V3A extruder, but has 2 new V3B extruders upgrade packets included in the deal. So i was hoping to install the new extruder before I get it going.
I can't seem to find any instructions on how to upgrade from the V3A to the V3B.
Also I am not sure if I need to update the firmware and if so, which firmware to use. I am not sure which Z motor I have, since I don't know when this machine was shipped to the original owner.
Could somebody please help me with this? I would really appreciate this.
Thanks,
Joost
v3A to V3B extruder upgrade
Re: v3A to V3B extruder upgrade
Keep the V3a and learn on it. It's actually a really good hotend for PLA & ABS -- better than the V3b. Upgrade once you irreparably damage it
If you've got a V3a, you're definitely on the classic 12v setup though. Order the 24v upgrade now and keep it in a box. You'll need it for just about any future upgrade on the machine.
Thank for the super quick reply!!
I will just start with the V3A setup and take it from there.
Once I do damage it beyond control though, do I just change out the hot ends, or do I need to do more? Like upgrading the firmware etc. The V3B kit also came with small fans, do those need to be replaced when I switch?
I will order the 24V upgrade kit. I had been thinking about that one and you just made up my mind for me.
Then I have one more question about the V3A hot end. There is a bunch of tape or something wrapped around the tip, so I can't see what the nozzle size is. Can I just take that off? How do I change the tip on this one?
Sorry for the long list of questions, but I am completely new to this and really appreciate all the help
Thank you for the super quick reply!!
I posted a reply yesterday, but it does not seem to have worked for some reason.
I will stick with the V3A nozzle and learn with that one first. Thank you for the suggestion!
When I finally really damage that one though, do I just switch out the nozzle etc, or do I need to do something more? Like updating the firmware etrc. Also the V3B kits came with a new small fan, do I need that or is it just extra?
I also had another question about the V3A nozzle. There seems to be a bunch of tape wrapped all around it including all over the nozzle tip. This way I can not see what size nozzle it has. Can I just take the tape off, or do I need to apply new tape, and if so what tape do I use?
How do I change nozzles on this one. Do I take out the whole thing and then carefully unscrew the nozzle, or is there a trick to it?
Sorry for all the questions, but I am completely new to this and I don't want to damage anything.
Any answers and replies would be greatly appreciated!!
It's most likely a 0.35mm nozzle, and you don't change them on the V3*s. You get another one. The firmware will need to be changed, because seriously go to the 24v setup when you upgrade..Joost wrote:Thank you for the super quick reply!!
I changed to the V3B nozzle and upgraded the firmware today.
Was able to get my first print to work out today. Needs some help but it's a start!!!
Thanks again for your help and yes, I am going to order the 24V upgrade tomorrow. Think it is worth it to just upgrade to the V4 extruder as well?
I am thinking about eventually upgrading to the dual extruder, but want to learn how to build a good model with the single extruder first.
Wish me luck.
Thanks again!
Wish me luck.
Thanks again!
