Eliminating the small errors
Posted: Fri Sep 16, 2016 2:03 am
Hey everyone!
First post and first complete top-to-bottom process of design, slice, print for me. I love the printer so far. I printed two of the bracelets when I first received it and they are both flawless.
Today I printed hexa.g that was included on the SD card and then sliced the hexa.stl using Simplify3D and then printed in order to see the quality difference. Mine was of lower quality and took different paths but was mostly okay. There were a couple little boogers on it unlike the first I printed using the .g that came with the card. The layer height also looked different. I'm just using a .fff profile I found for the v4 M2 (I've also seen it referenced here from other people using it). My guess was the .g included was set to a high quality print. Mine was set to medium. This seems about right because the hexa.g was around 15 minutes as the booklet instructed while my print was 8 minutes. So I figured I'd dive right in to a test print of my first model (I've modeled before but not for an M2 and never dealt with the actual printers and settings myself).
It's a top hat! I printed it on medium to save time.
However, I noticed a lot of little boogers on it as well as a distinct pattern along the backside from what I can only guess is the stop/start point of the outer perimeter top hat circle on each layer. I've read in various posts that there are lots of little things to fiddle with like retraction to eliminate some of these things, but I'm not familiar with all of the settings and their purpose since I've never been the one fiddling with them directly.
I've attached some images to explain what I mean.
Any help would be greatly appreciated! Some post processing will be fine but I'd love to get those perfect settings to get it right the first time. If it's as simple as "PRINT IT ON HIGH QUALITY, MAN" that will work as an explanation too, although it would be nice to know the tweaks between the two qualities that are causing these issues if that is the case.
