Weird Slicing Issue
colin
Weird Slicing Issue
Post by colin » Thu May 15, 2014 3:17 am
I am running into an issue I find quite confusing so I am turning to you guys for help. I am trying to print this http://www.thingiverse.com/thing:25829. I am getting some weird gaps in two of the three parts, the third part prints perfectly. I have tried reducing the coasting and eliminating the extra restart which did help slightly but won't eliminate the problem. The opposite side of the 2 parts also looks great. Any other ideas you guys have for what might be causing this.
(567.92 KiB) Downloaded 837 times
Re: Weird Slicing Issue
Post by jimc » Thu May 15, 2014 3:37 am
well i downloaded it and sliced it. i got nothing strange in the preview. are you printing in pla? i will assume it is. looks like maybe its getting too hot. the side that is printing strange, is that the side thats away from the bed fan? try printing a pair of these thing to see if it helps and maybe lower the temp slightly. if your using s3d can you post the factory file?
colin
Post by colin » Thu May 15, 2014 10:48 pm
This doesn't appear in my preview either, sorry so it's not a slicing issue. I am printing in PLA. It's Colorfabb white. I'm printing at 225C so i'll try it again at 220C. This is actually the side that faces to fan. I didn't save the factory file but I'll see how my next one comes out and post that.
colin
Post by colin » Thu May 15, 2014 11:15 pm
Apparently "The extension factory is not allowed."
Post by jimc » Fri May 16, 2014 12:33 am
colin just zip the file and upload it.
colin
Post by colin » Fri May 16, 2014 12:46 am
I can't do that either because the file exceeds 1MB (it's 1.8MB zipped)
Post by jimc » Fri May 16, 2014 12:48 am
ok how about the fff. zip that and upload it. that should be no problem and small
colin
Post by colin » Fri May 16, 2014 1:43 am
There we go. This is usually my go to for PLA.
BEST PRINT.fff.zip
(1.7 KiB) Downloaded 490 times
Post by jimc » Fri May 16, 2014 1:49 am
try turning the temp down by 5-10 deg then just turn the coasting completely off and see what happens.
colin
Post by colin » Thu May 22, 2014 7:04 pm
So I was able to get that print to come out much better with your suggestions. Then I tried using those same settings for a different print and I'm getting an issue where the print head is running into parts of the print now and i'm getting trace lines trailing behind the nozzle as it moves over parts.
