hi guys
I read about the option to replace the glass glass with aluminum . is the aluminum should be from any type of material ? ( as i know there are many kind of aluminum type )
i also that Insta is selling plates that is coated with PEI . Is it better and does the coat has to be renew after prints ?
Regards Doron
mic 6 plate
Re: mic 6 plate
It's much better in my opinion, and you just apply the PEI sheet one time. It's thick and doesn't wear out.
(You also don't need to use adhesives if you have it on the Mic6 plate.)
