The walls of the V4 part are a lot more predictable and smooth. I'm not sure why it's a matte finish, the temps are the same.
Unique situation available...
Re: Unique situation available...
Jules: Nothing, you're wrong
yes im sure you would have set them the same. temp are probably just different just due to the thermistor being located differently in the block or just the thermistor being at one end of the tolerance than the other one is. in any case the gloss is usually varies like that with the temp.i have printed that same filament in black as well and it always prints glossy because i tend to print on the hotter end of the temp range all the time. looks good though. the prints with the v4 look more controlled especially near the corners or start and stops. i kinda expected that with the shorter hot zone of the v4. nice test. i would be curious to see what the v3b print looks like if you did it but dropped the temp 10 deg.
Any lower on temp and the V3b tended to start skipping extruder steps, actually.
jimc beat me to it. I was simply going to type:
.... at the thermistor...insta wrote:... the temps are the same.
interesting. i am wondering if that is just from the v3b having the long hot zone and extra drag of the pla through that brass tube. i would suspect the short hot zone of the v4 plus the ptfe liner would allow pla to print a little lower temp. just a guess.
Perhaps, it still doesn't change the fact that the target temps were the same, although nobody has yet argued they aren't. The V4 print is definitely better for this particular PLA. I'm anxious to show my client the difference and get his opinion.
Now that does surprise me - the finish is exactly why I chose the one on the right as the V4. I have samples of items printed with both the V3b and the V4 all about the place now, and almost universally, the V4 printed ones give the shinier finish. (Although I actually do prefer the matte finish.) Huh!insta wrote:Jules: Nothing, you're wrong
Wonder what I did differently between the two?
(And from reading the subsequent posts, it might very well have been using a different temp on some of my prints between the two nozzles - I think I'm using a few degrees lower temp on the V4 than i did at first.) Might be worth experimenting with one day, if I ever get back up and running.
