Trouble getting started
nokianich
Re: Trouble getting started
Post by nokianich » Wed Jan 21, 2015 6:24 am
sorry, was busy for a while )
jimc wrote:Yes the filament drive that holds the hot end. Look at it with the fans removed. Is that not straight as well or is the hit end just crooked in the mount?
yes, that was twisted too. Today I was changing filament from PLA to ABS that got stuck and I had to disassemble Hot End and was noticed that filament drive was twisted too. now it is fixed. thank you everyone.
Dale Reed wrote:Looking at the picture, since it doesn't show the hot end, but rather the extruder motor mount, I think you're saying there's an interference between the hiring harness mount and the extruder motor connector (four color wires). Please understand that the extruder motor can be mounted in any of four orientations (connector at top, left, bottom, or right), to avoid the interference. Orient the motor so the connector doesn't interfere, but the harness wiring can reach it.
Does that help? I'm not at my printer to see which way I oriented mine. But I don't think my connector is at the top... Of course, I'll go home and look at it and it will be... ;-)
i was doing it the way manual says to do. as I said above filament drive was twisted too, no it is fixed :)
where can I read about S3D settings like retraction, first layer thickness, raft, multiplier, etc. and why we need all those things?
Post by jimc » Wed Jan 21, 2015 6:30 am
there is nothing official but jin has made up a how to guide for s3d a while back. newer s3d features wont be on there but youll get the basics. also goto the s3d forum. the past week one of the members there (keyboard warrior) started making some "tip of the day" threads and he is going over all the settings in each tab. he is up to 8 or 9 now i think.
