S3D Profiles
jdacal
S3D Profiles
Post by jdacal » Mon Jul 07, 2014 2:39 am
Still waiting on my M2 but I have a quick question about saved profiles in S3D.
I notice that when a saved profile is loaded the "Auto-Configure for Material" and "Auto-Configure for Print Quality" sections are no longer available. I'm assuming that if I want to have a Fast, Medium, or High print quality version I would need to save 3 separate configuration files? Just want to make sure in case I'm assuming wrong.
Thanks
jdacal
Re: S3D Profiles
Post by jsc » Mon Jul 07, 2014 3:13 am
That is indeed the case.
However! It turns out, if you open up the saved FFF file in a text editor, you can manually add back in autoConfigureMaterial and autoConfigureQuality sections, and then you can actually have those buttons work with your custom profile. I have attached the current profile I am using as an example.
MakerGear M2.fff.zip
(2.41 KiB) Downloaded 654 times
jdacal
Re: S3D Profiles
Post by jdacal » Mon Jul 07, 2014 3:18 am
Well that's cool! Thanks jsc
jdacal
