Hello,
I was wondering what the Z-Axis G-Code Offset in S3D actually does? Will the software make the the gap between the bed and the extruder nozzle "smaller" and ignore the Z stop limit switch? Using the JPEG as an example, from my understanding it will add 0.5mm to all the z-axis measurements in the G-code, therefore will it raise the bed closer to the extruder nozzle and go beyond the z stop limit switch.
This would be helpful as I would just have to be fairly close to the gap I want between the extruder nozzle and fine tune the final distance in the software.
I would worry that I might damage the switch if I would have it compressed more than it was designed for.
Mike
Simplify3D Z-Axis G-Code Offset
- S3D Z-Axis G-Code Offset.jpg (133.99 KiB) Viewed 5837 times
