In the scripts section of S3D there's a section for Ending G-Code - I'd like to modify that so that the bed doesn't slam down so fast at the end of a print. I've either got the Z-shaft too well greased or something isn't catching that is supposed to - mine comes close to dropping in free-fall.
I'm using a PLA spring under the bed, but it still whacks down hard enough to "kiss" the motor underneath.
Current default Ending script looks like this:
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
G91 ; relative mode
G1 Z10 ; lift 10mm
G90 ; absolute mode
G28 X0 ; home X axis
M84 ; disable motors
While using the spring, the Z axis settings run from 0 at the top (Home) to about 195 at the bottom instead of the original 200. (Or at least that is what it is now - the spring is being compressed a bit.) Ideally I'd like to stop the downward Z axis movement at about 190 mm from the top Home position. Or at least slow it down significantly while it travels down - I'd rather have it travel down under control.
Would this work?
G91 ; relative mode
G1 Z10 ; lift 10mm
G90 ; absolute mode
G1 Z190; (drop Z axis to just above spring?)
Or should I just eliminate that M84 command?
Is there a quick and dirty Reference Guide somewhere for G-code that says what each of those codes stands for?
Thanks gentlemen!
