CCVirginia wrote:Since you guys are so great at posting instructions, it would be useful to have one on "breaking down a hot end" - something I have avoided thus far.
Questions that come to mind:
* Do you unscrew the nozzle hot or cold? If cold, wouldn't internal plastic make it hard? If hot - ouch!
* The nozzle fits a wrench, but there is nothing on the other side - how do you keep from breaking things? What do you hold onto?
* What parts (like the sleeve) will be needed to put it back together.
* Any general disassembly/assembly hints?
* Any special tools?
* Is it the same for a V3b and V4?
ROFL! I'm still laughing at insta's description - You should not need to break down the hotend unless you are bouncing back and forth between PETG and PLA frequently without cleaning in between - but I did finally manage to get a bit of smut in there and the cleaning filament was quite jammed.
The V4 is very simple to break down, and if you don't have a death wish - you can actually wait until it cools down to take it apart.
(These guys are muy macho hombres, I tell ya!
) And here's the plus to cooling it off first- if you wait until it's cool, when you pull the nozzle off, all the crap in the barrel just slides right out attached to the nozzle. (Should have taken a picture of that, it was cool.)
It's like the ultimate cold-pull.
So what i did (V4):
Retracted the filament and made sure it was clear of the hotend. Cut the power.
Let the nozzle cool.
Removed the hotend. (Probably not necessary, but it was my first time and i wanted to see what was going on.)
Removed the little black cloth cover thing.
Took two pairs of adjustable wrenches and unscrewed the nozzle. Nothing more than a snug fit - the barrel comes all the way down to touch metal on the nozzle. It is not filled with plastic around the threads.
Took off the nozzle, and all the (not yet melted) filament in the barrel came out - still attached to the nozzle.
That was handy, because it gave a nice long handle that i could grab with the pliers and just sloooowly twist against the top rim of the nozzle. After a bit, the plug (with little bits of carbonized smut) popped right out of the nozzle.
Still some stuff left in there cooked to the walls, but it wasn't interfering with extrusion so i just put it back on. (You can blow torch it or dissolve the smut if you are so inclined - i just didn't have time to mess with it this time.)
Reset the Z and i was off and running again.
Pic of the plug that came out - that tube is hollow, and it's the residue left on the walls of the barrel after you retract. (Caught most of the crap that was left on the walls, too.) The crimped spot is where i caught it with the tweezer nose pliers and pulled it out of the nozzle.
- Eeeew! All that carbonized crud on the tip!
- Plug.jpg (187.9 KiB) Viewed 10282 times
