M3 Probes Breaking
pyronaught
M3 Probes Breaking
Post by pyronaught » Mon Nov 05, 2018 4:54 am
We got 10 new M3 printers at work recently and have been running into issues with the Z probe tips bending frequently. I think they drag across a defect or blob left on the print surface and this causes them to bend and require replacement. Has anyone else run into this? Seems like a more rugged sensor should be used for this.
makeal
Re: M3 Probes Breaking
Post by makeal » Fri Nov 09, 2018 3:27 am
Yep they are fragile. Someone posted about this that they broke 2 . Also seen it on other forums
SIERRA086
Post by SIERRA086 » Sat Nov 10, 2018 12:32 pm
Did I see correctly that the m3 uses a bl touch? Oh man how I despise those things. One of the projects on my list is to convert my z-probe-less M2 to accept a piezo disk so the nozzle will act as the probe. I did a piezo conversion on my other printer and have to say that it’s the best z probe I have tried yet.
Post by ednisley » Sat Nov 10, 2018 2:12 pm
At the risk of auto-horn-blowing, a simple microswitch on the X gantry has behaved pretty nearly perfectly for the last five years:
It has some compelling advantages, at least for me:
  • Senses the actual top surface of whatever platform you're using
  • Doesn't require a metallic sheet
  • Uses straightforward G-Code, not even a wizard / app / whatever
  • It. Just. Works.
Installation required a bit of metal bending:
https://softsolder.com/2015/03/10/maker ... is-switch/
Marlin 1.1 changed the G-Code tweakage:
https://softsolder.com/2018/02/13/m2-pl ... confusion/
AFAICT, it's a whole lot easier than a BL Touch installation.
Bonus: no fragile / expensive / fiddly components!
I started with the switch on a plastic block and perhaps something like that will work on an M3:
https://softsolder.com/2013/10/14/maker ... in-switch/
SIERRA086
Post by SIERRA086 » Sat Nov 10, 2018 6:18 pm
Hey - to each his own - looks good though ed. The micro switch method is solid as well.
makeal
Post by makeal » Sat Nov 10, 2018 6:54 pm
Yep it uses bltouch on left head only
Post by airscapes » Sat Nov 10, 2018 7:34 pm
Can you post a link to the particulars of this conversion?
SIERRA086
Post by SIERRA086 » Sat Nov 10, 2018 7:50 pm
https://www.precisionpiezo.co.uk/ - I'm not in any way sure how I'd go about adapting it on the m2 yet, but this is where I got the piezo setup for my custom built printer
After trying going with no z probe, then a mechanical switch, then an IR sensor, I finally landed on the piezo setup after reading through this: https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe.
I'm sure some people might think I'm full of it or overdoing it, but really isn't this the beauty of 3d printing? There's 100 different ways to do something and we are each free to find what works best for us. I'm just sharing my personal experience.
