insta wrote:dammit jules put the abs goop on some kapton and print with that spool of ABS
But i
hate starting over again, knowing nothing, the struggle, having to adjust it for Zebra printing since i am NOT going to reset that stinking Z-stop again, making thousands of post-its worth of notes again.....
(want a little whine with that dinner.....?
Geez, just figuring out PETG here.......let me enjoy actually feeling comfortable for at least a minute or two!
Before i tackle ABS - I was thinking of rigging a second Zebra plate with a Kapton cover, so i can use the juice to stick it at the lower Zebra temps. I'm hoping (and it might be crazy wishful thinking) that there might be less warping/splitting if we can print the ABS at a slightly lower temp, so that there is less temperature differential as it cools. It might work for very small prints, but it sounds like ABS needs the strength of a metal plate to keep from warping up, if you print bigger items.
It's worth experimenting with, but i need more time....there's
never enough time to do everything i want to try.
