Metal Bed (Aluminum or Stainless) Will it work? Benefits?
jcspball13
Post by jcspball13 » Fri Oct 16, 2015 3:06 pm
I work at a sheet metal shop, so getting a piece of metal to replace my bed would be easy and cheap. My question is: will it work, would it work better, and what problems could I face?
Would love the help, and if it works, would be able to provide users here with extras for pretty cheap!
Any input would be great!
innkeeper
Re: Metal Bed (Aluminum or Stainless) Will it work? Benefits
Post by innkeeper » Fri Oct 16, 2015 3:55 pm
see this thread:
viewtopic.php?f=10&t=2014&hilit=mic6
there are many others with alternate print surfaces.
Post by insta » Sun Oct 18, 2015 6:06 pm
jcspball13 wrote:I work at a sheet metal shop, so getting a piece of metal to replace my bed would be easy and cheap. My question is: will it work, would it work better, and what problems could I face?
Can you get me a flat sheet of steel milled into a 310mm disc? Something like 10ga steel ... looking for 2-6mm thickness. I'd like the surface flat to within 0.05mm (0.002"), if possible.
Need this for an inductive probe bed on my delta :geek:
MIC6 would also work but it's way more expensive than steel.
