thank you
Thumb screw for M2 Bed Leveling
Re: Thumb screw for M2 Bed Leveling
you are welcome!
post your make on thingiverse if you make them!
If it is an ANSI threaded screw (this one isn't) and number 10 or smaller, I can usually shear it off pretty cleanly with my stripper/ crimping tool. If it's Metric (this one is) I grab it in a vise and using a cut-off wheel in a hand grinder (Dremel tool) cut off the portion that makes it too long. I usually run a nut down the length of it which will clean up the thread when I remove it after the cut. I also like to clean up the end with a grinder. Given the size of this one, though, this can be a bit tricky.
BTW, the design of this improvement is really nice.
Thank you for the tips. Came across this https://www.amazon.com/Antrader-M4x16mm ... 07K698LLX/ these are 16mm which should work without cutting
todinskino
After owning the M2 for several years, I don't really see a need for this modification. Once properly level, if you don't put undue stress on the platform man handling the build plate, it says level for months. I typically get my Dial indicator and mount out and level it once a year just for good measure.. This is not a cheap import machine that is made from inexpensive materials that come loss and move around in normal use.
But if it helps you out, by all means mod away!!
