So I have my laptop next to my M2 - I set everything up / copy code to SD card / set M2 to print from SD / select the code .... and off it goes happily printing.
I unplug the USB & power cables from the laptop & wander off to another room to carry on using it etc ... leaving the M2 whirring away.
A couple of hours or so later the printer is still happily going strong - I come back into the room, sit down at my desk, plug the laptop power cable back in & (not thinking!!) plug the USB cable that is lying on the desk next to the power cable in as well.... Sadly, this interrupt to the M2 overrides the current job from the SD card, and the printing stops half finished !! DOH! ....
I appreciate that I should just remember to unplug the printer end of the USB cable instead ... but is there any way to "un-pause" the M2 at this stage (simply unplugging the USB cable again doesn't work - its too late sadly)? Alternatively, is there a simple instruction that I can always add to any gcode saved to the SD card to basically say "once you start this job from the SD card - ignore any USB connection until you've finished!"
I'm guessing that I just need to retrain my brain - but thought I would ask the question ...
