Getting running in ABS as soon as I get my M2
Re: Getting running in ABS as soon as I get my M2
Post by jimc » Wed Jan 21, 2015 5:44 pm
x2. if your not set up for acetone vapor what you will want to do and assuming those are abs pipes and your going to use abs pipe glue to put them together...dont just glue the joint. coat the entire inside of the cap so it makes a nice abs liner when it dries. as bryan said print low with a wide extrusion width and just slightly over extruded.
Post by insta » Wed Jan 21, 2015 8:12 pm
wait how do you know my name :ugeek:
Mind
Post by Mind » Sun Mar 01, 2015 9:21 pm
OK, I went snorkeling with the thing. Not even 15ft, and the end caps leak. Even through areas that were acetone smoothed and are solid fill printed and 8mm thick!
So I drilled a hole in the tube, let the water out and filled it with polyurethane expanding foam. Hopefully that keeps the water out and provides the design buoyancy :)
While being pressurized with the foam, the end caps spewed water/bubbles/etc out of all sorts of places. VERY strange, but I guess the lesson is: 100% fill is NOT solid material (there are micro-channels etc).
Post by jimc » Sun Mar 01, 2015 11:07 pm
yes it can be difficult to get a watertight print. a little over extrusion helps but still no guarantee
Matt_Sharkey
Post by Matt_Sharkey » Fri Mar 06, 2015 12:59 am
you cant change the fact that we are effectively printing little spaghetti strings all over the place. My impression is that 15ft of water-tight is impressive for a 3d print.
Could your 3d print be used as a model for homemade injection molding? (wait, is homemade injection molding a thing?)
Post by jsc » Fri Mar 06, 2015 7:21 am
Some sort of sealer, perhaps? I've been playing around with XTC-3D epoxy, but for functional use almost any thin two part epoxy might work.
rsilvers
Post by rsilvers » Thu Apr 16, 2015 6:55 pm
eSun PETG is even better for underwater than ABS.
That is why they make water bottles from it.
Vprints
Post by Vprints » Thu Apr 16, 2015 8:04 pm
Matt_Sharkey wrote:(wait, is homemade injection molding a thing?)
Yes. :) http://gingerybookstore.com/InjectionMo ... hment.html
(I have some of the Gingery books, oft-perused though I haven't had the opportunity/space to implement yet. But having a 3D printer to make parts from PLA for investment casting should make it pretty nice when I finally do :ugeek: )
-Vprints
