S3D freezes/not responding
I am having the problem of S3D freezing up/not responding when I try to "repair flipped triangles" and "parsing g-code" for this certain model. In the past I have had problems generating support, repairing, and post processing other models. Computer specs:
OS: Windows 7 Pro
CPU: Intel Core 2 Duo E8500 @ 3.16GHz 2.85GHz
Ram: 8GB
GPU: NVIDIA Quadro FX 3450/4000 SDI
My hardware is above the minimum system requirements for S3D...
OS: Windows 7 Pro
Ram: 8GB
Re: S3D freezes/not responding
Try netfabb for your model debogofying needs. They have a downloadable free program, but their net service is easy to use: http://netfabb.azurewebsites.net
Most of my files are good. I just run the repair as a good practice. Unfortunately, I do not have permissions to install programs and that still doesn't solve the problem of generating the g-code.
The net version could repair the model to get a good model that s3d won't choke on.
After having trouble with the first part, I decided to try a different part. Everything worked fine, so I backed out of that preview and imported the part I was having trouble with. Set everything up and hit prepare for print. This time it worked...does S3D just need to warm up with a practice file
Also, I bought S3D so I wouldn't need any other programs. What is the point of have this "amazing" software if it wont even work.
I would say you have a computer issue. The software has been nothing but flawless on my machines. Maybe try a restart.
Having issues slicing the same part today again. So I did a restart of the system with no luck. The system is well above minimum spec... Time to contact S3D?
Is this a part that you can share with us?
alloy, as jin said we can probably help but we need to see something. when your model fails can you save it as a factory file then zip the file and upload it here.?
I will have to get back to you on sending the part. I know I can't upload it for anyone to grab but I might be able to email it to a couple individuals.
